Discuss LG 43UK6300 Backlight & sound but no image in the Electrical Appliances Forum area at ElectriciansForums.net
snufkin
Hello guys/girls
first time here. I have a problem with an LG TV and I want to fix it myself.
I bought a multimeter and I was advised to check the T con.
If I run over the different components. I arrived at this conclusion
LED: not causing the problem since I have a faintly lit screen (backlight) + torch test that shows no images
Power supply: I have sound, the TV is on. work perfect
Mother Board: Can/ should I test it?
T-Con: the first thing to test...
So - Big problem. after watching a lot of youtube videos and having an idea of what a T-Con is. I didn't find my T con. the motherBoard is connected direct to the Screen component.
(in the pic, I demonstrate that the cables come from the Motherboard direct to the screen component)
But I found an interesting video on youtube of someone who fixed the same problem with just a ....blue pen:
this is exactly what I see when I open my TV
I advise everyone to see it since among the dozen of solutions I saw - this is the most original.
I tested the Right cable and a dim white square is shown on the screen
I tested the right cable and there is no white square on the screen. Does anyone know what does it mean?
Can I apply his solution to my situation? is it worth buying 2 new cables to exclude the possibility that they are faulty od can I use my multimeter to run a test
If u arrived here - I thank you a lot
I will b happy to receive any advice
Reply to LG 43UK6300 Backlight & sound but no image in the Electrical Appliances Forum area at ElectriciansForums.net
On eBay you can find hundreds of Samsung (but also LG, Philips, etc.) Smart TV motherboards (see e.g. here Samsung UN65JU6700FXZA Main Board...
Telly seemed to be on the fritz and then we couldn’t get it to load up a screen at all, power on etc, light flashes when using the remote but no...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Firstly, I hope it is ok to discuss the wiring of speakers here. TBH my ignorance in all things electrical knows no bounds, and I am guessing it...
