Discuss Light switch 2 gang 2way with neon - UK in the Lighting Forum area at ElectriciansForums.net
Jwaugh
Hi. Does anyone know if it’s possible to get a 2 gang 2 way light switch with at least one neon. I’m putting lights in the roofspace and there is a switch at the top of the stairs, beside the loft ladder, for the landing light. Was looking to see if I could put another switch here but want to be able to see if the lights are on in the roofspace.
Click minigrid offer decent options for this - could either have a separate neon module or use the twin width module that has the neon built into it - either option would fit a 1 gang plate.
There is, or was, a fitting available, containing a neon, that was sandwiched between a plateswitch and its back box. It was intended to help locate the switch in the dark.
think MK did them with a green indicator lamp.
I have seen something like this but does the light only come on when a particular switch is on?
connect between L and S/L and the neon lights when the switch is off as the S/L acts as a false N. connect between S/L anf a true N and it lights when the switch is on.
Reply to Light switch 2 gang 2way with neon - UK in the Lighting Forum area at ElectriciansForums.net
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
Is the following set up possible with a 3 Gang 2 Way Smart Wifi Switch set up (the black glass type touch ones) One of the 3 switches, switches...
