Discuss Lighting Circuit Spur Q&A in the UK Electrical Forum area at ElectriciansForums.net
Hi Gents,
Just a quick question. I'm adding some lights to an extension, just a few spots which I plan to take from the existing downstairs lighting circuit using a junction box.
Question being, do I need to add an FCU?
I'm comparing this this adding a spur to a ring final circuit and if adding more than one socket, you'd add a FCU.
Does the same rule apply to lighting circuits? There's going to be about 9 spotlights and two outside lights.
Has RCD protection etc
T
if you are taking the feed from a lighting circuit, no need to add a FCU as it's already on a 5A/6A fuse/MCB. just ensure that allconnections are compliant and safe. test circuit after alterations.
The point is that the requirement for an FCU applies to adding more than one socket to a RING FINAL circuit.
Lighting circuits are RADIAL circuits where there is no restriction on the number of devices/accessories on a circuit subject to (but not restricted to):
  • cabling distance
  • the value of the protective device on the circuit and (of course)
  • the total demand.
Reply to Lighting Circuit Spur Q&A in the UK Electrical Forum area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Evening all, Been to a job on Fri where the customer had a condition report completed. Two of the remedial identified was that there were too...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Hi, looking for some ideas on this. I went to an address on Tuesday following a storm where property has been struck by lightning. When the...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
