Discuss Lighting circuit through airing cupboard in the DIY Electrical Advice area at ElectriciansForums.net
Red and black cable could be as new as 13 years ago. The life span of such cable is well in excess of 50 years so no need to replace.
Perhaps the previous fitting overheated the end of the cable, in which case it needed cutting back a bit. Or perhaps the spark was looking for unnecessary work. Modern cable, whatever the colours, has a life in excess of 50 years.
I'm sure you may well be correct. The house is now 43 years old so it may well be original and coming to the end of it's life.
For me, I would feel a lot happier just getting it out of the way now and then I will know I don't have to worry about it again. Knowing there are question marks over how old and how much the install has been hacked about over the years will play on my mind so I'll just crack on and get it done.
Really appreciate the honest advice you have given here. Thanks
There is an important caveat missing from these statements about cable life, and it is critical, so I'll fill in what I consider to be the missing bits....
"Modern cable, whatever the colours can have a life in excess of 50 years, providing environmental factors do not prematurely degrade it."
I have many examples of modern cables that have lasted much less than 50 years (some only a couple of years old) and it's usually been down to their environment.
Reply to Lighting circuit through airing cupboard in the DIY Electrical Advice area at ElectriciansForums.net
Hello I have recently moved home and I looking to upgrade lighting across the house to LED. In the kitchen I have found that there is installed...
Hello I have moved into a new house and the electric meter and consumer unit are under the stairs. What i want to do is put a door there so can...
Hello, Behind a tiny door in our under stairs cupboard we’d like to build a miniature room in which a little light would come on when the door...
Hi all, I have a light in the under stairs cupboard which is controlled by a switch in the hall. The under stairs cupboard is being taken...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
