Discuss Lighting issue in the UK Electrical Forum area at ElectriciansForums.net
Has anyone come across this before, client told me all lights were working previous to fuse board change, but when I turn light on in one room to a fitting with lamp in, it trips out RCD, when lamp is removed and light switch is turned on and off RCD stays on, all other light fitting with lamps in on same circuit(4 in total)all work as they should, I have checked insulation resistance , there is 230v between live and neutral when switch on at the lamp holder , then 0v between live and neutral when switch is switched off. This has got me totally stumped, please help
Does just one RCD trip, or two?
If two RCDs trip, then expect a borrowed N - the circuit for the light in question, and the circuit the N is borrowed from.
if juts the one RCD trips, perhaps that light is wired across L and E, and thus tripping the RCD when operated. Could be mixed up connections in a ceiling rose, or elsewhere.
Yes I noted that, not sure why you raise that? Before a CU change with no RCD, a L to E connection would not be noticed, after it would trip the RCD. And testing with no lamp in place, perhaps would not be noticed (or, of course, no testing!).
then the borrowed N is favorite. what you could have is a 2 way light with N from the upstairs lighting cct. and L from the downstairs. if up and down lights are on different RCDs then that would cause 1 or both RCDs to trip when the light is switched on with a load connected.
this is a 1 bed flat, with 4 rooms in total, only 1 lighting circuit, no 2 way lighting anywhere, all other lights can be on, and bedroom light switch can be on with no lamp in place, and all power stays on, as soon as you put a lamp in and switch light on, RCD trips
Reply to Lighting issue in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Removed an ancient light fitting, replaced with a newer one, the light comes on but can't be turned off with the switch. It was working...
I've been asked by a client to 'mask off' the green LED charging indictor lamps within several emergency lights fitted within bedrooms on a...
Sorry no photos, but I’ll explain best I can. Turn on the switch, I’m not getting any light. Apparently a new fitting. Description…. A white...
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
Hello everyone, Hope you're all well. I'm carrying out an overall/global insulation resistance test on a newly wired 3 phase installation we did...
