Discuss Load Balancing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
how do i balance the three phase system wire into 5 floors?... give me examples plz plz help
So you are not married then Ahmedsalad 2 floors on 1 phase 2 on another leaving the 5th flat on the 3rd phase, the phases won't be fully balanced but in this scenario I feel that the best option, if there are any communal loads you can add them to the phase feeding the 5th floor flat.
Reply to Load Balancing in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I know the effect of a lost neutral (floating neutral) on a 3 phase system, and the theory of why the line voltages can vary. However, I have...
Hello gents I need your help plz. Lets suppose we have 15 led lights bulbs on a 2 core cable. I chopped 5 of them coz it was too long for the...
Hi everyone, this ones a first for me but weve been asked install and use a three phase supply in a large new build house. The 16 way dis board is...
BIG place OK lots of electrical bits. but one on a 3 phase Radial is tripping its RCCB so i check the wiring making sure its tight and it has...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
