Discuss Megger 1552 MFT continuity testing???? in the Electrical Tools and Products area at ElectriciansForums.net
hi
I have recently bought a megger 1552 tester. it is in very good condition as it was just used as a back up. i have a slight problem with it though when trying to use it for testing continuity. basically i can only carry out one continuity test and then i have to turn the tester completely off and then back on again to test another time. is this normal or am i doing something wrong? im sure you dont have to do that especially for a £300 tester!
thanks for any advice given
well i am very confused. as soon as there is continuity the tester buzzes for about 2 seconds whilst flashing a battery sign in the corner and then stops buzzing. it doesent even give a reading!
it cant be the batteries as i have just replaced them
Send it away for a quote for repairs, how did yo pay for the tester? credit card? if so claim on it if it's a duff meter.
thanks everyone.
i have just rang megger and they say it is an internal component fault or an internal fuse has blow!! :(
i bought it of ebay so have some bones to pick with the seller!!
anyone have any idea where i could get it repaired and calibrated?
thanks everyone.
Your local friendly Wholesaler may be able to point you in the right direction, some hod "calibration days" just ask them.
Hi did the eBay seller describe it? Did they mention any faults, did it come with a calibration certificate?
1552 are getting old now and spares are getting a bit scarce.
Let's not jump to conclusions about the seller. It may have worked perfectly the last time it was used, which if it was a backup could have been some time ago.
Meter do a turn around on repairs a default of £280 including calibration. Someone else might be able to fix it cheaper , but if they can’t they send it to Megger..........!
Mine is still working strong if you have put new batteries in it and the problem still persists check the fuse as it could have come loose in transit or blown if continuity is done on a live circuit.
thanks everyone for the advice
i have bought some new fuses and hopefully that fixes the issue. if it doesent then i will have to find someone who can repair it.
megger told me they wont do repairs on the 1552 anymore as it is fairly old model so will have to find someone.
Reply to Megger 1552 MFT continuity testing???? in the Electrical Tools and Products area at ElectriciansForums.net
Hi I've got a megger mft 1720 that I was hoping any one can shed any light on When performing continuity tests (even when nulling the leads)...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
Hi, I currently have a Megger 1730 v1 which is fine for all functions except the 2 wire (L-E) no trip loop test, (no 3 wire loop test on my 1730)...
