Discuss Minor works - Like for like in the UK Electrical Forum area at ElectriciansForums.net
Going back to the op original question , here is an example i come acroos a lot , carry out an eicr and there is a 32 amp mcb protection a 2.5mm radial socket circuit on the 2nd floor of an office.
We are then ask to carry out remedial work, now do you .
A. downrate to a 20amp mcb.
B. downrate to a 20 amp rcbo.
B.
It differs from house to house but we generally install radio link bases downstairs from existing light fixtures then replace the existing landing smoke with a radio link and hard wire from there to upstairs rooms via the loft.
Don't usually know where last point on circuit is, usually not too hard to figure it out though.
Just curious... Does your alarm system signal something if one of the devices drops of the network? If so do mind telling what brand/range you're using?
Am i the only one who minor works everything?
If i change a cracked lightswitch like for like i carry out a full range of tests and certify it.
Reasons are habit, and also do alot of work in social housing so always wanting to cover my back. Photo of every job also saved in the computer job file.
No hope of me issuing a MWC to change a cracked light switch. I doubt house owners issue themselves a MWC when they replace a light switch.
Do you also issue a MWC when you replace a customer's light bulb?
It's your choice. He was only giving his opinion.
I can see why you're not bothered but in a commercial installation where there might be a high turn over of staff, insane members of the public around etc would you not want to know if a socket has been changed once every 2 years for the last 6 years? That sort of info is very handy and MWC is best way to record it
I must be slow, because obtaining the results for the MWC and completing it takes me longer than a couple of minutes, and more so when the understairs cupboard is full of rubbish.
Not disagreeing with you but you make the assumption that, especially in a high turn over of staff scenario, MWCs are kept and can be found in two years time.
I've seen many, on outer appearances, competent and compliant additions. All with company sticker, labelled and dated that you expect has had a cert issued in its time.
As to see the certs for it and you may as well be speaking Swahili.
Reply to Minor works - Like for like in the UK Electrical Forum area at ElectriciansForums.net
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
Hi All I have been asked to supply a minor works certificate on a smart thermostat upgrade. Would I just test the dedicated circuit from the CU...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Thought it'd be interesting to see for those who are self employed. Work for themselves. As I'm doing level 2 . Nice to see how others already in...
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
