Discuss Modify 12V downlight to take 240v lamp in the UK Electrical Forum area at ElectriciansForums.net
mrx01
Hi,
I have 19 12V downlights in my living room that I am thinking of changing to 240V LEDs (out of the Kosnic range from CPC, already put the 6w flood ones in instead of halogen in the existing GU10 holders in my kitchen and am impressed!).
I currently have the Tamlite Starlite range of 50w fire rated fittings installed with 12v TEC electronic transformers on each fitting. The sticker on the back of the fittings state 12V max 50w, and there's a class 3 symbol, which I believe to be SELV only. Therefore can I safely swap the G5.3 lampholder for a GU10 if double insulated and loop the twin and earth straight into the 3 pole block at the top of the fitting, or use HR Flex from the Joint box already in the ceiling? Or will there be earthing issues?
An alternative could be to use one of the existing transformers or new LED drivers to feed 4 or 5 fittings to avoid minimum loading problems and keep 12V lamps in?
Any guidance much appreciated.
just fit the GU10 holders. the 12V only is then irrelevant as it's the lamp holder that's meant for a 12V lamp, not the fitting.
Reply to Modify 12V downlight to take 240v lamp in the UK Electrical Forum area at ElectriciansForums.net
In the bathroom we have a panel above the wash basin with 3 x 12v Halogen downlighters powered through a single transformer. I am looking to...
Hi, Been looking to replace a set of downlights that have seen better days. Been doing some checking of what's in place to see whether it's just...
Hi Simple question I think - is there a specific cable requirement for connecting up 240v 6w LED downlights in a daisy chain extending the...
Hi guys, Bare with me, hope this makes sense.... I have 3 separate mains (240v) lighting circuits in my kitchen all going back to a 3 way 1G wall...
Hope this is the correct forum for this. I have a chandelier that holds 18 bulbs, it's not in use since ages ago and I was planning to restore...
