Discuss multi room audio systems in the Home Media Centre Forum area at ElectriciansForums.net
L
llywelyn111
hi
I'm after some information regarding a multi-room sound system. We wire about 6 chalets a month for a company, they have a customer how wants six chalets with a multi-room audio system form a central hub with either a single controller or multi point controller. Where can you buy these systems from? I presume they are wired in cat 5e / 6?
Has anyone wired one of these and where is the best place purchase the kit from?
Also would it be possible to get one audio and visual multi-room system
regards
David
sonus systems are the best, they cost alot but are really simple once you have done one, the main bridge goes at the hi-fi or tv amp then the rest is interlink wirelessly, you have a box for each room that the ceiling speakers go back to. it also streams music, you hae to get a cat 5 to one of the units from the broadband. hope this helps.
One of the guys here has started experimenting with Z-wave controls to be able to run their sound system throughout the house. Has anyone here had any success with Z-wave? It looks promising, but I don't know much about it.
Sonos all the way mate. The functionality of what they offer now is awesome and it really is a piece of ****, highly recommended not only from an installers point of view but from a users.
I've recently fitted lots of Sonos and Rako Rak4 systems and they are fantastic. You could use the Sonos amp with ceiling speakers and hide the unit away it makes for a very neat job. I also used a NAS drive to store all the clients music on so he could access his musis anytime without having a pc on.
Reply to multi room audio systems in the Home Media Centre Forum area at ElectriciansForums.net
I am wiring a garden room which will be a home office, customer wants wired ethernet points and wifi down there from the house router Its too far...
I have just removed the keypad module (art.3188) on a comelit vandalcom audio intercom and blanked it off. I installed a siemens K42 keypad lower...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Hello, I have installed 6 recessed lights in my living room as well as wall boxes. I’m now at a point where to need to run the wiring. I plan to...
