Discuss Normal for a house alarm to be on upstairs lighting circuit? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
For a few weeks I've had my upstairs lighting circuit on and off at the board, not noticed anything.
Last week my decorator buried some of the cables coming out of the alarm box (just above my fuse box/consumer unit). When I now switch on the upstairs lighting circuit, there's a red light on my alarm box and the alarm goes off. If I turn the lighting circuit off, the alarm shuts up.
Worth noting - some sensors were taken off as part of his decorating (so the wires in the corner of the rooms now don't have sensors on)
This is confusing me for a few reasons:
  • This didn't happen previously (he's not aware of knocking anything, but even if he did, it now seems to work more as it was entirely silent beforehand?)
  • Should an alarm be on the lighting circuit?? Doesn't seem right to me but I'm not an expert
  • Even if it is on the lighting circuit, why would turning it on kick the alarm off? I thought the idea was that the alarm was triggered when power was lost in case of an intruder deliberately cutting the power supply
Any help on this greatly appreciated, bit stumped.
I don't see a problem with having the alarm on a lighting circuit. They don't take much current.
Where was it initially wired to, before the decorator came in?
Was it all working before he came in?
I'd be considered about the missing sensors that were taken off.
"This didn't happen previously (he's not aware of knocking anything, but even if he did, it now seems to work more as it was entirely silent beforehand?" - I don't understand this bit.
Depending on what bell you have, if the power goes off then the bell will go off. They have a small board with a battery in the bell box for this. Your battery may not be working in the bell box. Hard to tell.
If the sensors have now been removed the alarm will sound due to the tamper fault. If it's only sounding when the power is on, the alarm panel battery is probably dead. Are the sensors going to be refitted?
Not unusual, and most likely to do with removing the sensors as the tamper/alarm/+&- wires have to be correctly re-terminated if still planning to energise the system with a sensor(s) removed.
you may have more than 1 fault.
1, panel battery goosed.
2. fault due to removal of sensors, could be a blown fuse in panel.
3.flat or faulty battery/ pcb in bell .
It’s very normal.
Reply to Normal for a house alarm to be on upstairs lighting circuit? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
