- Reaction score
- 55
I need some guidance on the regs as they might apply to an installation running off a small (4.4kw) petrol generator in the back of a vehicle.
The customer's idea is to turn a small truck into a coffee vendor.
My plan so far is to simply provide a hook up from the generator via an outdoor BS 60309-2 connection straight into a garage unit with a 30ma RCD as the main switch, supplying two circuits, i.e one coffee machine and one water pump.
The issue I've come up against is earthing - the generator is intended to be contained inside the vehicle. That's a floating earth - what do I need to do to make it comply?
