Discuss Outside Socket Question in the UK Electrical Forum area at ElectriciansForums.net
Whilst it probably isn't unacceptable, it is a poor job and would.probably benefit from being re-done. Which is probably a simply job
Most of the RCD sockets/FCU's I've installed in the past conform to BS7288, which according to the posted reg 531.3.6, doesn't appear to be suitable. I would however seek some guidance on that.
nah, they only nicked the plug bottom.that's the bit with some scrap brass.
There has been a lot of posting of late regarding RCD sockets and spurs not being recognised by BS7671 I have read a few posts (some from SC) where using an RCD spur for additional works to comply with the regs as not to have to change the P.D. does anyone know the reasoning behind this.
I am trying to resolve this question myself but the IET specialists only work on a Monday or a Friday.
There are two types of RCD those that are latched (also called passive) and which will stay in the on position when the supply is switched off, and those that are unlatched (also called active) which will trip when the power is switched of.
Unlatched RCDs would be used when a hazard would occur if the power supply was suddenly restored - e.g. to an electric lawnmower.
Latched RCDs will only trip for a fault and so would be used where it would be undesirable for them to trip on a power supply cut-off. A good example would be for fridge-freezers or freezers.
One manufacturer I have spoken to states that it was not the intention to stop the use of RCD sockets, and that the Regulations in that respect have been poorly written.
Hi stp motors,
I'd be weary about what other DIY elec jobs have been done by current occupier tbh. That's a dodgy attempt at installing an o/s skt.
Would you plug an extension lead onto an extension lead?
When something gets plugged in its acting as a spur off a spur so not correct at all.
What is the fuseboard like? ie has it got rcd protection.
I advise if you get property that should be the first thing on your list to get sorted.
If circuit is already rcd protected it ought to be cheap and quick job for someone to do a similar but more professional job such as ideally spurring off nearest socket putting a switched fused spur adjacent then go directly into back of outside socket to connections (so no holes are shown it only needs moving to the right 6inches or less).
Oh just read were you say no rcd protection offered from fuseboard.....first job you need now is a new fuse box. Unlucky as your now looking at a ball park £300 job for a professional job (18th edition fuseboard).
I hope for your sake (and the sparky you get) there's no borrowed neutrals on your lighting circuits................
Hi stp motors,
It's not like a spur off a spur at all, because it is fused at 13A in the mains plug. It's no different to plugging in an extension cable, it's just that the socket is screwed to the wall.
These kits are a DIY method of providing an outside socket without involving Part P.
Some kits come (or came) with RCD sockets, and others without for use when the socket circuit has RCD protection.
Possibly, after a quick mental risk assessment, considering load, total cable length, CSA, route, suitability of cable and connectors for the external influences present and of course inspecting the condition of cable and connectors.
Can you quote a regulation number or anything in the ISITEE CoP to back this up?
Section 15.10.1 (Table 15.4) of the ISITEE CoP (4th Ed.) shows maximum lengths for different CSAs. Whilst 15.10.3 recommends avoiding 'daisy chaining' multiway adaptors, these are different to extension leads.
I would ask for an EICR prior to purchase and factor any remedial work required into my offer. Most vendors aren't going to squabble over this nowadays.
I did get carried away your right it isn't a spur off a spur but I don't like it and advise they get it done properly.
Also yes we've all plugged extension leaders into extension leads ie on construction sites but that's a temp setup not advisable is it.
Thanks for all the advice guys. The seller didn't want to pay for an electrical inspection, so we paid for one ourselves.
The results were quite amazing...
1. Fuse board had no RCD protection so has to be replaced (we knew this before the inspection anyway).
2. The outside socket in the pics above had a damaged/split cable and needs replacing. He'll also wire it in properly at the same time.
3. There's a socket underneath the sink, next the to u-bend. The casing is cracked and water dripping into it.
4. There are lights outside by the front door, that the sparky says are internal lights, not designed or safe to be placed outside.
5. There's a security light in the back garden, which was wired tino the light switch for the back bedroom (i.e. turn the bedroom light in, the outside light comes on).
We've managed to negotiate a sizable chunk off the asking price given what was found.
What made it even more surprising to us is that up until last month the seller had been renting the house out. The sparky made a point on his report of saying the house didn't meet the standard required for rental. (A rogue landlord it seems).
Which specific standard for rental is that?
Maybe he just means his EICR had an 'unsatisfactory' result.
Nearly every house I test I find at least as much as what is listed above. Quite lucky it's all relatively easy to rectify.
Reply to Outside Socket Question in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hi. I'm in the process of getting my qualifications and am taking on some small jobs for family to try and get some experience in. Today I was...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
