Discuss Oven and Hob - Wiring help needed in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys,
I am after a bit of advice, I am fitting a new kitchen and I am having to spur off our old gas oven which has its own feed back to the box, Our new oven which will be all electric will be on the other side of the room with its nice new shiny Isolator, My question is will I be able to run the Hob and Oven off the same Isolator ?? I am pretty confident that I will but I just want to check first, it will be around 2 metres away from the original socket but as I am spurring it with suitable cable.
Thanks for your replies in advance
Sam
So you are diverting a "unknown to us"size of cable from a original position, via a unknown sized cable to a unknown rated hob and oven,there is no information on how its extended or whether it will feed a accessory at its original position
The protection for that circuit is also unknown, as is the means of routing the cable to its new position
You may need to provide a little more information before opinion can be given :)
Reply to Oven and Hob - Wiring help needed in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm installing a Hoover oven and would like a little help please. The oven code is HOC3158IN. The oven manual states "The power cable must...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
Hello everyone, I've got a new oven and have a question about installing it. It's a 2.6kW 13A oven, and a cable from the 32A cooker circuit to...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
