Discuss Pattress for old MK socket in the For Sale and Wanted Forum area at ElectriciansForums.net
sionevans
Looking for a metal pattress with screw fittings in the correct place for this old MK 2 gang
socket.
The existing pattress of the socket that I am looking to replace has fittings on the side.
Really useful site, thank you @snowhead
I love places where you can get "stuff" not easily obtained elsewhere. The range of fabric covered flex is amazing, and I love the "large" ceiling rose that will cover the mess under an older, small or standard rose
Dual boxes are slightly wider and it's unlikely those lugs are correctly spaced. It also has a divider that would prevent the socket screwing back.
The prior link is for a standard 2 gang flush box with 'back box repair clips', which Google will show you, but obviously you'd have to set spacing without the aid of a convenient template.
Reply to Pattress for old MK socket in the For Sale and Wanted Forum area at ElectriciansForums.net
Hi there, I am looking for some advice re: putting new sockets and usb sockets in my home. Someone will be rewiring the entire house but I have...
I have had three led strips installed under wall units as part of a kitchen refit. A new pattress box was fitted in a stud wall next to an...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Wanted - Vintage Mk Electric Light Switch 4 Gang 2 Way - need of 3 these longer type of switches - 3 or 4 gang would be ok
