Discuss Pet Sensitive PIR in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi, just wondering if anyone can recommend a decent pet pir for a cat?
I have installed a Texecom petwise at a property but they say the cat is setting it off at night, never had any problem with these in the past.
Cheers
climbing curtains then,tell your client to sling the cat out side at night and tell the cat to stalk a dog .
climbing curtains should not be a problem. the pet friendly PIRs go by body weight, maybe it's a real fat cat. if so it should run a cps scam scheme
Cats go all over the place at night, it’s quite amazing. If the cat can climb in front of the detector it will look this big.
Cheers
Don't know what panel you are using but you could always set the circuit to double knock
Cats and intruder alarms don't mix unfortunately, even with pet sensors.
Your best bet is trying to contain your cat to a certain area of the house and configuring your alarm so that area is turned off upon setting. Still probably not fair on the cat though if it's fairly active.
Hi. Pet sensitive detector adopt infrared ray to detect. Once it detects something, it will make a alert. So when you install the Pet PIR detector, you can install it at a high location. It can avoid false alarm to some extent.
Reply to Pet Sensitive PIR in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi everybody. We had a Texecom system installed 3 years ago. Earlier this year we had a battery problem and the installer came back and changed...
Hi I’ve recently installed a texecom veritus excel alarm system but having an issue with the sounder not going off when triggered by the pir I’ve...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Hi all, I'm looking for a couple of PIR floodlights to replace old halogen ones, probably around the 50W mark would provide sufficient lighting...
Hi, just wondering if anyone could help me. I’ve just installed a texecom Veritas alarm in my garage at home and can’t seem to get rid of the...
