Discuss PIR Continuity in the UK Electrical Forum area at ElectriciansForums.net
I bought a PIR for an installation the other day and I was intending to use it for a contact but as soon as power is applied the live and switched live have continuity whether the PIR is triggered or not, I’ve tested a couple of different PIRs already installed and this doesn’t seem to be the usual case. The PIR works fine if wired into a light fitting but I’m after using it for a contact. I’m just wondering if I could ‘adapt’ it to suit or whether I should just try another PIR?
thanks in advance for the help.
It’s common for a PIR to close for a few seconds when power is applied....for example when the MCB is turned back on or after a power cut. What are you using the PIR for?
The PIR constantly has continuity even if it’s been on for ages. Whether the PIR is triggered or not there is continuity between the two contacts. I’m using the PIR to trigger a relay.
Swap it for one of the PIR's already installed if they are testing OK for your purpose and the one you have operates normally with a light.
So you have 230v at the relay coil terminals which is energizing it permanently.
Yeah, it’s never not triggered regardless of whether the PIR is triggered or not.
[automerge]1583909065[/automerge]
This may or may not help;
Just to sanity check wiring
I thought that originally but I’m 100% sure it’s as I thought now
I can’t, this one needs to be one for an internal angle and the customer is very specific on atheistic. I think I’ll just have to get another brand and hope for the best.
some PIRs don'tlike inductive loads (relay coil). try a 0.1 mfd capacitor (300V, non-electrolytic) across Lout and N.
Reply to PIR Continuity in the UK Electrical Forum area at ElectriciansForums.net
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
So I’m an apprentice and only get to do downlighter jobs as foreigners at the weekend, but they’re typically added when the customer no longer...
So I just started out recently and I’m struggling with what to price myself at. It’s worth noting I live in the east London area and I’m looking...
