Discuss Plastering directly over T&E in the UK Electrical Forum area at ElectriciansForums.net
T
tedglen2
Hello all.
I have goggled filling T&E with plaster and there are a lot of responses saying plaster will corrode the cable?
Is this just a myth? Will I be ok to just clip the cables then plaster over myself!
Hello all.
So have you consulted your electrician or is he a figment of your imagination?
He said plaster... just checking, because you never know if your dealing with a cowboy. Murdoch, there is no need to be a cocky **** now is there ?
Render or Multibond first then plaster for a smoother finish.....a thick depth of just plaster tends to shrink and crack.
I would always advise a qualified sparks checks any cableing first to make sure everything is correct before filling in as it prevents the possibilty of haveing to re-plaster when forms are being filled in due to faulty circuits.
not 100% sure meself but from reading other threads seems to be no problem.......unfortunately i'm one of those sparks that still uses capping as personal preference to just clipping, though the regs say capping isn't necessary (hard to teach and old dog new tricks i guess).
agreed capping looks nice but if wall being dot and dabbed (95% of time for me) I don't bother. Chases in existing walls, well, the capping is there to stop the spreads trowel (hence plastic capping) and its in a 'cut' in the wall so it's protected.
BUT I agree capping, done with skill and pride, looks best.
Although highly unlikely, it's my understanding that render is thought to be potentially destructive to PVC sheathing of T+E. So directly in plaster is OK but if installing in render use capping/conduit or other mechanical protection.
Ted, if you are ready to plaster than I am presuming that all the cables are in? This would be an ideal time to get the first fix tested for continuity and an insulation resistance test carried out.
This is where wago connectors work a treat:thumbsup
not ready for testing, just thinking ahead really !!!
Inspection and testing should be carried out before, during and on completion of works. It saves getting to completion and finding a fault. It is possible to find faults on new cable or for unknown mishaps to occur during installation. If you're thinking plaster and the first fix is not complete then it sounds like you may be jumping the gun ;)
Long ago in days of yore it was recommended that cables be capped. The Electricity Board inspector was liable to take an accessory off and see if the cables were loose (capped) or fixed (plastered) and I am told would refuse to connect if not capped (mine were always capped so never found out if this was true). I am told the cable sheath is now resistant to plaster and that used not be the case with the original PVC sheath. So bury in plaster, but I still prefer to cap them even in a chase.
New posts
Reply to Plastering directly over T&E in the UK Electrical Forum area at ElectriciansForums.net
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Seen a couple of videos with Doncaster cables now producuing a T&E with the CPC already sleeved so no need to fit our own. I also read somewhere...
I'm obviously still new and learning about what I can and cannot do, but essentially I want to install an EVSE at my own house for an electric...
Client has had a meter installed for a new consumer unit in their shop they are looking to rent out the spare space for a barber shop so they want...
