Discuss Power to outside shed, does it need TT earthing in the UK Electrical Forum area at ElectriciansForums.net
Hi hope someone can help. The shed in the garden is about 15m away from the house. Its supply is spurred from kitchen ring via a 30Ma RCD/13A FCU, the load side of the FCU (2.5mm flex) runs outside and underground (within metal conduit) to an adaptable box where its joined to 2.5mm SWA which runs to the shed. At the shed the SWA is terminated into a 13A FCU, which supplys' 2 sockets and 2 strip lights.
Does this installation require a TT earth system as a matter of course. As it is now the earthing arrangement is via the CPC (including SWA). The house has TN-S system.
can i ask why didnt you run the swa from the outside point by the fcu to the shed, seems an odd way to run power to your shed ?????????
To update, ive found that exporting the TN-S is not looked at favourably; so does the SWA need to be earthed via the TT.
No the SWA dont start at the house FCU, it starts at an adaptable box under the patio. Dont know why I didn't install it, but i see what you mean
if it was me i would be looking into getting it change (you might not like that) because unless he has applied some gel and maintenance free connectors, water could get in and corrode / short thing out bad practice if you ask me
I think if you managed to export TNS anyone looking at it would be very impressed! How on earth you can sell an earthing system to another country is beyond me!
However if you were talking about extending an existing TNS earthing system and equipotential zone to include an outbuilding then there is no problem at all so long as you do it properly with respect to the requirements for bonding.
If there are extraneous conductive parts in the shed then there would have to be a main bond of the appropriate size for the intake position (normally 10 mm for a domestic supply)
If you did need to create a TT earth for the shed then the SWA would not be connected to this, it would need to be isolated from the TT earth and connected to the TNS. The bonding and cpcs in the shed would connect back to the MET of the TT system.
Its concreted in
you have just found a nice little job as all joints must be accessible so you might as well rip it out and run in armoured cable into the house,or possibly install a weatherproof isolator then you will not need to rip whole of existing cable out. Simply run new armoured cable from supply side of isolator into property.
Reply to Power to outside shed, does it need TT earthing in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi all, I'm planning on adding some lighting to an old stone shed, there's currently a 2.5mm² SWA supply to the shed only supplying one IP rated...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
As the title says, I am looking for a recommendation for an enclosure and gland arrangement to electrically isolate or divorce the earth/armouring...
5K
