Search the forum,
Discuss RCDs then RCBOs tripping. in the UK Electrical Forum area at ElectriciansForums.net
Apart from that the RFC end to end readings etc are filled in against a 20a radial [wrong box] and the 1.5mm main lights circuit also has a 1.5mm CPC apparently, does my head in the lack of care on an important certificate.
It works the other way around too, when you have a mate do all the lighting and you do all the sockets on a rewire. You sit and start filling out the forms by hand (Tablet not working) and just as you're finishing off he decides to mention that he did the lights in 1mm not 1.5mm. (Sigh)
did nobody pick up the main switch bs5419 not 100 amp main switch on test sheet and Rcbos for circuits and you wonder why he has a problem.
Not sure what you are getting at Buzz, regarding the use of RCBOs, could be missing something though.
On the basis the OP has chosen to conceal when they are on the forum I can only suggest they are not intending to take this further ............
The supplier isn't going to do much more unless you can prove that your installation isn't clear.
I would find another electrician ............... issuing an EIC with no IR tests completed isn't a satisfactory way to conduct such a change and certification IMHO
I'd get him back to do it properly and if he won't I'd complain to NICEIC as that's apparently who he's registered with. I think I'm right in saying they don't like/allow non NICEIC sparks to use NICEIC headed forms.
what are you on about ,there is serial number on the test sheet that will show which NICEIC electrician has them .
Reply to RCDs then RCBOs tripping. in the UK Electrical Forum area at ElectriciansForums.net
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
I had a 6amp RCBO feeding a 2.5mm radial ( temporary measure) It tripped, as I expected would But once tripped, all the other circuits went...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
