Discuss resistance values in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
mpc4000
hi i was juist watching this youtube clip about resistance in series and in parrallel and @ 2:48 of the clip he comes up with some values 60/3 & for the love of god i cannot work out
anyone can put me right i would be most gratful
thanks
[ame="http://www.youtube.com/watch?v=W8USCMCW3ww&feature=related"]YouTube - Physics 13.4.2g - Parallel Circuit Example[/ame]
I have no idea how he has done that but he gets the correct answer. lol. I did it like this:
V=I/R so to find R you need V/I
120v/6a = 20 ohms
He is using
1 = 1 + 1 = 1 = 1 + 1 = 2 + 1 (use common denominator); =
Rt~R1~R2~Rt~30~60~60~60
Therefore;
Rt = 60 = 20 Ohms (he should have shown this first IMO)
(1)~~3
@ 2:48 he could just said that R=
120 = 20 ohms:rolleyes:
~6
easiest way to get the resistance in parallel
1/Rt = 1/R1 + 1/R2
1/Rt = 1/30 + 1/60
1/Rt = 0.033 + 0.017
1/Rt = 0.05
Transpose this so Rt = 1/0.05
therfore Rt = 20
Now using ohms law V/R = I
120/20 = I
therefore I = 6 Amps
Not what the OP was asking
he was asking how the video guy worked out the resistors in parallel
i can be quoted as saying
'easiest way to get the resistance in parallel'
I was showing him another (much simpler in my view) method, one which I would hope helps him
one which doesn't arse about with trying to work out common denominators :rolleyes:
60/3 is an equivalent fraction of 120/6. They both produce the same outcome, and it makes doing these calcs in your head easier.
Reply to resistance values in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
5K
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
I have a job coming up where I likely need to replace old twin and earth (imperial size) feeding one, perhaps two flats in a 3 storey converted...
Hi all, Grateful for your expertise regarding my confusion on the below. Context: French rural domestic property Single phase supply, TT...
