Discuss Robin De-lock Loop Tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
somersetsparks
Hi all,
Just wondered if someone could tell me why my Robin Loop Tester with de-lock will only test through BS4293 Rcds? As soon as I use it on a 61008 or 61009 it will trip it?
I do normally use a megger with de-lock and its fine, but I like to use the robin for industrial/commercial tests.
Robin's D-lock method of ELFI testing attempts to desensitise the RCD by swamping it's mechanism with DC 'blocking' voltage as part of the high current loop test pulse. This method works with BS4293 RCDs, but the newer BS EN 61009 types are much more testing-sensitive and D-lock is very often not effective.
Megger have never used the DC blocking method as it was covered by Robin patent. Initially Megger used a variation of the now common single pulse low current (15mA) EFLI test method which injects a current below the residual trip current of the RCD. Later this was superseded by their patented low current multi-pulse method that is much less sensitive to electrical noise.
Reply to Robin De-lock Loop Tester in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi guys & gals, I gave in and bought the new Megger MFT-X1. Got my hands on it Friday night, had a little play with it, used it at work on Monday...
HI, I bought the TIS MFT PRO from CEF, nice touchscreen etc, so in the future I could add on the EV dongle and have a fancy case and tester etc...
