Discuss Running branch to shed in the UK Electrical Forum area at ElectriciansForums.net
I want to do a run to a subpanel in a shed - about 50'. 3 circuits: lights, electrical, spilt. I have an isolation panel - can this be retrofitted with a subpanel circuit to branch off to the shed?
You are not allowed to add or change anything in that panel. It looks like an Eaton meter base/ main breaker combo and in this picture you have no way of installing a main breaker to feed a sub panel
thanks for that. So full run to main load center - not a problem, a little longer run but easier in some regards. Appreciate the advice!
Reply to Running branch to shed in the UK Electrical Forum area at ElectriciansForums.net
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
Hello! My shop is currently on a single 15 amp circuit. Is like to upgrade it at the main home panel to a 30 amp. Do I just need to run 10 gauge...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
