Discuss Running cable in cavity in the UK Electrical Forum area at ElectriciansForums.net
you running it up cavity or just straight through, inside to outside?
Just been looking at regs for this. Using flexible conduit should provide strain relief and a compliant bend at the top cavity point of entry - that's where most of the mechanical stress would be (reg 522.8.4 and .5). It would also provide protection from falling debris (reg 522.6.2).
Dont like it.
Anything in a cavity that shouldn't be there has the, very real, potential to bridge and cause damp.
Agree. Never a good idea. And there's the risk of someone drilling through the wall and not having any clue that it's there.
Reply to Running cable in cavity in the UK Electrical Forum area at ElectriciansForums.net
I would like to hide the cable to an EV charger. The consumer unit, meter cabinet and charger would all be on the same wall. About 5 metres from...
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
Happy New Year all. Quick question regarding cable sizing. I have a 25m run from DB to car charging unit. The 25m run will mean approx 8m is run...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
