Discuss S plan heating system in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi guys new to the forum. I’ve landed on a job on a dental surgery. The plumbers have installed new heating and got water system and basically left me to wire it up. Struggling to get my head around it and could do with some help. They’ve installed two boilers that are going to work together, two pumps one for c/h one for h/w. There’s three zone valves two for downstairs and one for upstairs. There’s also a h/w cylinder with a cylinder stat. They then want three room stats for c/h two downstairs and one upstairs. Any would be appreciated cheers
It’s basicaly an S plan+
The only thing that has thrown me is the two pumps? what type boilers are they?
No valve for the H/W then?
Are you a qualified sparky?
Separate these zones and the hot water system and draw it out should be easier to get your head round
Cheers for the reply’s guys. Sorry I missed the valve for the h/w it does have one. The boilers are Worcester ones. I’m a qualified spark I work on mainly commercial buildings. Not done ant s plan since the am2.
Draw it out on paper for the heating separate from the hot water just to divide and conquer and you will see its rather simple as it's all in series pal.
You need to tell us.
so you have 3 heating zones (2 downstairs 1 upstairs) each one with a valve and controlled by a room stat
1 H/W zone valve controlled via tank stat.
two pumps one for the system? one for secondary return?
Is this correct?
If it’s a secondary return it should be obvious as it will be plumbed into the cylinder secondary return...The pump will have bronze or SS impellers and the housing is usually yellow if it’s a grundfos pump.
Hi,surely you mean in parallel,with isolation? In series,would give the return/flow sensors,something to think about...
Two boilers in series. If there’s a Fault with one they still have heating and hot water. They have fitted a low loss header to the system aswell
You didn't think to.mention the low loss header at the start of the thread then?
Based on this new information you will almost certainly have a boiler circulating pump which will need to be controlled by both boilers via a relay. This pump circulates water from the boilers into the low loss header.
The second pump will be circulating water from the low loss header and around the CH and DHW zones.
Worcester bosch will send you a wiring diagram of how to connect two of their boilers together if you give their tech support a call. It is important that you do this bit correctly otherwise you may damage the boilers or create a dangerous situation for anyone working on them in the future.
Have a look at boiler sequencers
....I have done...many,many times:)
This is why i know they are paralleled and not in series.
I did a two line post,hoping to get more detail,and Dave blew us out of the water with his thorough retort:)
These are systems and features,which are not added "ad-hoc",most generally specced and designed from the get-go. If this is the case,there will be system drawings for both the hydraulic and electrics.
If not,Dave's last paragraph is applicable.
Hey guys. I got this information off the plumber today, we’ve got 3 wireless programmers, 3 x 2 ports (heating) 1x 2 port for the cylinder,frost stat, 2 x secondary heating pumps (they’re the main system heating flows,stats will control these)2 x primary heating pumps (shunt pumps) cylinder stat, and secondary return hot water pump ,
2 x Worcester 40 cdi classics, 2 x grundfos 25/80 SF pumps, 2x grundfos 15/60 PR pumps, 3x Honeywell 2 port valves (heating) , 1 x Honeywell 2 ports (hot water circ) cylinder stat, frost stat and grundfos gold pump HWSR, #CONTROLS# 3 wireless single channel programmable room thermostats, 1 x wired hot water timer
It’s simple to wire if you break it down. It’s a lot of work to try and explain it or knock up a diagram. It might be easier if you do a diagram and I/we can tell you what needs changing etc if anything.
Reply to S plan heating system in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
Hi, I’m not an electrician or a plumber, but I am confident diyer and am not completely incompetent! I have a new build house with a boiler/hot...
4K
A combi is heating 5 ufh zones downstairs and 1 radiator zone upstairs. It has a two port valve for each. My question is, would you fit this with...
