Discuss Security system question in the Electrical Engineering Chat area at ElectriciansForums.net
I have a four camera wired system.
I fancy adding a 5th camera.
I have an idea that someone may have invented a splitter box that could rotate from one camera to another say every 30 seconds - so that you can cover 2 areas for the price of one channel on the recorder.
any other ideas would be welcomed.
TL;DR
Splitter box for security cameras . Is there such a beast!
It’s analogue unfortunately. It’s quite old!
You certainly used to be able to get switching units for composite video sources. The problem is each of the 2 cameras will be off line for half the time.
As above, get an 8 channel DVR, they aren't expensive.
Reply to Security system question in the Electrical Engineering Chat area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Hello all, new here. I’m searching for advice whilst brainstorming the idea of installing an additional 12v battery in my car to supply the...
Hi, New to the forum. I have two very specific questions, for the setup below. Setup details: Currently I have a setup with an outlet used for...
Hi, folks.' I have a carrier 38MGRQ48E '5 zone' mini split system with 4 'heads'/evaporators installed, and one 'channel' still open. Had it...
