Discuss Shared / Borrowed Neutrals in the Australia area at ElectriciansForums.net
V
Vessy
Hi, does anybody know (through experience) where borrowed neutrals are normally picked up?
1960's house, CU in garage, both lighting circuits only have reds at the CU, wiring routes from garage through wall to top of stairs (under floor).
Havent had a chance to lift the floor as yet, just wondered if they would be commonly in this area where all the cables combine or if it could be anywhere?
I'm also presuming it would probably use a neutral from the ring circuit?
Have never had to deal with shared neutrals as yet so any info from experiences would be great.
Thanks, Mark
1960's --- look under floor for spliff dog ends.
no, seriously, could be anywhere under floor. look for junction boxes, or follow lighting circuits back from lights. beware of lighting wired in twin, no cpc
Good chance the lights are run in conduit 5/8 or 16mm in new money so they would have run 2 reds and 1 black and if it is run this way look at the upstairs landing
and if you are very lucky you will see 2/3 short floor boards lift them and if there is a 3x3 joint box look for the pipe with the 2 reds &1 black one of the reds should go to the common joint and the other should pass through the box.
Forgot to add it depends about the layout of the house most JBs are on the landing or a central area
Hopefully will be where makes sense!
Lighting circuit is quite quirky, two single reds from CU (one up one down) this is looped through the light switches, no cpc at switches. light fittings have a neutral loop (single black) but the fittings do have a cpc, this is a single bare cable loop to each fitting.
Love the fun jobs!!
usually you will find the lights wired loop in live at the switches from 3 or 4 fuses at the CU, this will give isolation on one lighting circuit from each fuse, but they only run one neutral back to the CU, this make splitting circuits up a bit of a pig on dual RCD boards. I have also found added wall lights supplied from lighting circuits with the neutral taken from an adjacent socket.
Cheers..........Howard
SirKit you say it is a pig of a job to duel RCD so my question is where do we stand when changing a CU and the lighting circuit is either run in conduit with no seperate cpc or in the case of this post has a shared neutral
if lighting is in tube, then can we not just pull new CPC? as for shared neutral, if the circuits together are not pulling more than the CCC of the cable, then can you not common the feeds into one MCB/fuse? so all of the lighting is then one big unconventional circuit?
Yep you could pull a a cpc in the conduit but one small problem if you are in a flat then the guy upstair would not be too happy if you wanted to lift his laminated floor to find the joint box the reason I asked the question is I am getting enquires from customers who are in this situation and me being a timed served 14th (yes 14th) edition spark who was taught that if the conduit is "mechanically and electrically sound" then you could drill and tap an earth stud into the conduit or switch box in other word the light circit is encased in one big earth and I was just looking for an interpetition or definition
Yep I am getting enquires from customers who are in this situation and me being a timed served 14th (yes 14th) edition spark who was taught that if the conduit is "mechanically and electrically sound" then you could drill and tap an earth stud into the conduit or switch box in other word the light circit is encased in one big earth and I was just looking for an interpetition or definition
14th edition. I had to look that up.1969 so you know all the 60's houses then, good member to know. Found out on Home - Voltimum UK - Electrical Installation Products and Contracting...... Very interesting history on there. But I won't call you old, oldtimer :p
Yea Yea I started my time in 1975 and funny enough I worked in the industrial commercial environment I did not go near housing unless I was doing a job for the family
Unless it is convenient to get new neutrals into the lighting then unfortunately they will all have to go onto the same side of the board, not ideal but it is compliant. If you cant pull a new earth in then you will have to bond the conduit and use that, again not ideal but it is better than no cpc at all.
You young boys in the trade for 5 minutes ........................1972 bet you had to file down the 1" conduit to get the 25mm^ dyes to bite as well mate. My old boss was that tight I reckon he bought all the old imperial conduit up, Hammer and rawlplug tool as no cordless drills and the Yellow book
Listen Malcolm do not open up old wounds when I started we were using metric gear on imperial jobs and as for the dreaded rawplug tool all I remember is rubbing cream on the soars at the end of the day so could I give battery powered Dewalt a run for its money ? Not bloody likely Mind you I sometimes go into the garage and look out my rawplug tool (yep still got it just in case it makes a comeback) to bring back fond memorys (not)
Lol ................ as an apprentice we rewired an old telephone excahnge in London. Myself and another lad marked out the runs, pinged the lines and the sparks came along to mark the saddles position for the galv conduit.
This was a battery in the basement so concrete. Off I go for the drill and was given hammer. rawlplug tool and 3 No10 bit's with the advice "off you go son and mind that's all the bits your going to get so break them, you buy new ones" ............happy days
Was still using the my old bosses raw plug tool up until the point I left him 3 years ago. On a breeze wall it's quicker and less dust is made than a drill.
Brown fibre rawlplugs or plastic
Putting the Tallow in a Quality Street tin to stop the rodents getting a free meal Aye they were the days now its matching Dewalt hand tools /boots/trousers and sweatshirts my my how things have changed
Forgot to add that I had to wash the 4 company (Holiday Hall) vans in the depth of winter with a bucket sponge and no hot water mind on a friday afternoon at the depot
Bought a Yankee Pump screwdriver with my overtime 1 week, was the dogs danglies with this and cost nearly 2 quid !!! Was showing the lads on the top floor of this 5 story office block that was being built when the sparks came up and asked what have I there,
Handed it over, he took 1 look and dropped it 5 flights down the rubbish shute. walking away muttering if you wanted to be a chippie son ............
Still have it at home, but never worked as he bent the spindle...............
My Yankee is next to my rawplug tool, bit and brace, my 20mm bush key and MICC T bar my late old Dad made for me (Jan wheres the Kleenex)
Whatever happened to the proper bush spanner. The onesthat had the 2 jaws with one of the jaws elongated that was 3/4" one end and 1". You could swing on those things to tighten a bush, these bush king spanner things are useless
You can still get the open mouth ones.
And it's red Rawls for me, those janky drivers are lethal if you slip trying to put to much effort behind them
You're probably guessing right Vessy. I expect the neutral has been picked up from the ring circuit. As you have probably realised it wouldn't be a good idea to follow Johnnyboy's advice of putting all the lights on one cicuit as this wouldn't give any discrimination in the event of a fault. Look out for cross linked strappers on upstairs/downstairs two-way switching. The used to run only 2 strappers, this means downstairs two-way light runs off upstrairs fuse and vice-versa.
Haha, rawlplug tool's, yankee drivers, brace or handrill. Only a week after i started as a lad my Boss gave me a Yankee driver to speed me up a bit fixing up ceiling roses. After many slips into the ceiling (and my left hand) i reverted back to a Pozi! Funny when i think back to how useless i was for those first few weeks!
Reply to Shared / Borrowed Neutrals in the Australia area at ElectriciansForums.net
Hi everyone, I want to repurpose an old cable that was previously used to power a 3-phase machine. The cable is 4L1.5 micc, and I don't want to...
Evening all. I did an EICR recently and then changed a consumer unit. As part of the EICR process I take off around 25% of all accessories to...
Hi, I have an ongoing issue with an RCD which keeps tripping when bathroom light (not on RCD) is turned off. The issue doesn’t happen every time...
Howdy DIY soldiers, first post here. My question comes down to whether it would be particularly unsafe for me to temporarily wire nut and tape a...
