Discuss **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
proteus as well. classy job that.
no mcb? just stick it in the switch that will do.
Was the circuit at least protected within 3m?
Nope this was a run of about 35metres ! Fused spur on the end
:leaving:Did they use the yellow phase as earth ? lol!
Sketchy one I discovered today.... Directly supplied from DNO 100amp cut out, cables have also been crushed under the busbar shield :cowboy::cowboy:
Sythai,
I hope you realise where you’ve put this. Show us YOU’RE installs.
Yes I know you found it, but I hope you have a tin hat.
Reply to **Show Us Your Installs!!!** in the Australia area at ElectriciansForums.net
