Discuss Smart lighting 3 core to switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In the coming weeks I will be re-wiring my home. For the lighting circuits i will be using 1.5mm cable. ideally I would like to run the feeds to and from each light switch so that there is a neutral at the switch for smart lighting. However to avoid more damage/decoration I will be using the existing conduits in the wall to each switch but they are not big enough for the extra cables (feed in and out) so my thought is to run a 3 core to each switch (Live, switched live and neutral) would this be satisfactory for the new regs? Also if I fail to even fit the 1.5mm 3 core in the conduit would it be wrong to run the switch cable in 1mm and the feed cables in 1.5mm?
Cheers
best way is to 3 plate at the lights, drop a 1.0mm 3 core from each light to it's switch. that way you only have 1 cable in each switch drop tube and still have N at both light and switch. and why 1.5mm? 1.0mm is more than adequate unless you're fitting high wattage tungsten lights.
Spot on cheers for the quick reply lads. 3 plate at lights it is with 1mm drops. And yes your right with LEDs these days I suppose 1mm is adequate. I’ll do some workings out today. Cheers again
Reply to Smart lighting 3 core to switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I’m looking to install 3 meross smart switches for 3 lights: entrance switch: only 1 gang but 3 way switch bedroom switch: 2 gang (1 is 1...
I can't seem to find the right answer for a smart switch installation for a light that has THREE switches. There's conflicting information, and...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
I genuinely can't find a 3 gang 3 way black smart light switch - any ideas where I can get one from? Seems to be hard to get hold of?
