Search for tools and product advice,
Discuss Smoke alarm on wall in the UK Electrical Forum area at ElectriciansForums.net
If you've got a make/model in mind, check the manufacturer's instructions. Aico say ceiling mount only.
Fireangel sw1-r, found this installation guide. Just not did a lot of fire alarms so just looking for advice
A quick scan of guide to building regs gives - Ceiling mounted alarms must be 300mm from lights and walls.
- only detectors and alarms suitable for wall mounting are to be wall mounted and fixed above doorway height.
Reply to Smoke alarm on wall in the UK Electrical Forum area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
any BS 5839 experts know whether CO alarms should be connected to the smoke/heat alarm system ? after completing an efixx CPD it seems they should...
i had a builder do some work but now my smoke alarms turn off when the lights are off, does this mean i can only have a fire when the lights are on?
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
