Discuss Socket live all the while in the UK Electrical Forum area at ElectriciansForums.net
Hi can someone shed some light on the above ? swapped out a single gang wall socket ( working perfect ) for single gang with usb, simple job wire up like for like. however the flick switch on the new usb socket which was working perfect for two days does now not cut the power and the socket is live all the while even when the flick switch is in the off position. I thought it was a faulty switch so took it back and got a replacement but the same has happened again....works fine for a couple of days then the flick switch part wont cut the power.....thanks in adavance
Is the power still live when you flick the switch or are you talking about the USB ports as they are normally permanently powered. Do you still have the old socket and what make are the new ones you bought?
power is still on (3 pin plug part) when i flick the switch to the off position and i assume the usb part is live all the while anyway
this is what i got BG 13A 1-Gang SP Switched Socket & 2-Gang USB Charger Port White | Switches & Sockets | NoLinkingToThis - https://www.NoLinkingToThis/p/bg-13a-1-gang-sp-switched-socket-2-gang-usb-charger-port-white/6914f
Did you buy a LAP one out of screwfix by any chance? If so return and never buy again, cheap DIY rubbish
there again, just fitted 24 chrome accessories for a client. all LAP , client's request. 1 twin socket had a duff switch. other than that, no probs.
could be a bad batch. try getting it swapped for a schneider or click ( if click do the usb ones).
I think any company with the initials BG is probably best avoided! Saying that I have recently fitted a fair amount of the BG Nexus metal plate range, and they seem alright. The customer wanted to go with Lap at first, but I pointed them towards the numerous bad reviews saying that the switches give up the ghost after a couple of years. You pays your money and gets what you get!
One of my favourite face plates are the range of screw-visible low profile flat plates by Schneider. Around a tenner per socket, but good quality and look smart IMO.
Link:
schneider flat plate - Google pretraga - https://www.google.co.uk/search?q=schneider+flat+plate&client=ms-android-google&prmd=sinv&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiDofq6t7XZAhVGDsAKHRvuABQQ_AUIEigC&biw=377&bih=542
Being available as they are these days with the grey inserts is very smart - I don't like flat plate old style but will have a look at these. Always good to know what's available.
I have found on standard BG double pole sockets that under a heavy load the switches have failed, normally failed by shorting but could just weld themselves together.
If the load you have normally connected is in the 2.5 - 3.0kW range and you are switching it off using the socket switch then this could be the cause.
You just did the post i was going to do! Love it :)
I have a good few of the white metal ones at home. They are like a 'posh' version of a standard placky white socket! Photo of them from side on for how they sit as it's not obviously shown on the Google images (ignore the breakfast cereal on the floor!):
They have a nice foam gasket firmly attached to help seal them.
Reply to Socket live all the while in the UK Electrical Forum area at ElectriciansForums.net
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
