Discuss Spur off a spur in the loft. in the UK Electrical Forum area at ElectriciansForums.net
Goose
I have recently moved into a new build which has a passive input ventilation unit in the loft. This is cabled to an unswitched fcu which is spurred off a single socket which is in turn spurred off the ring. Am I right in thinking that you shouldn't have a spur off a spur?
As it is a new build surely you should snag it with the builder. I'm sure the "powers that be" would be interested in non compliant wiring in a new build as well. Is this part of an estate, and are all the others non compliant as well?
Given this is in the loft, is single socket for a TV booster or the likes? And so perhaps all of this is off the lighting circuit?
Thanks guys for all the replies. It is an issue I will be taking up with the builder. I have checked next doors and theirs is the same. Makes you wonder what other non compliances exist on the development. I have ascertained that the single socket is not a radial; it isolates off the upstairs ring breaker.
Just another example of poor workmanship. We have had an exceptionally long snagging list. Some of it, like upstairs sashes fouling on the brickwork when opened, blockwork in the garage bowing out and a front door warped and the frame not plumb, I don't class as snagging. What happened to attention to detail and taking pride in the work that you do.
Reply to Spur off a spur in the loft. in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, newbie posting! Does the following sound ok... Existing circuit: SOCKET on a ring -> spur to SWITCHED 3A FCU -> SWITCH -> hardwired FAN...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
Hi everyone, I've got an electrical ring circuit that looks somewhat like the drawing below, where the blue sockets are part of the main ring and...
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
