Discuss stairlift in the Canada area at ElectriciansForums.net
H
harl
hi does anybody know what trip you need for a stairlift and also does it run off the 2.5 ring.
thanks for your replies.
harl
Normally i wire them direct from the mains in 2.5 T&E to a RCD fused spur located near to controls at the top of the stairs. As wiring from the ring i don't see a problem but if I'm not mistaken the manufactures instruction require the lift to be separate. You better check.
Hi,
All of the stairlifts that I have done are battery powered and the spur is only used for charging the batts. The installers always ask us to change the fuse to a 3A.
Hope this helps.
Cheers,
Lofty
Reply to stairlift in the Canada area at ElectriciansForums.net
An Invitation to Retired Electricians anywhere except the UK with Four Days a Month for a Niche Opportunity That Can Earn 15K a Year. There are...
stair lift was off its charging section at top of stairlift track for some time rarly used. and upon checking batteries were dead. could not move...
I need to long term store a Acorn 130 stairlift carriage with internal batteries that is removed from the rail. The carriage normally picks up...
4K
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
Im running a ring main for all my sockets using 2.5 cable....as an after thought i was thinking to spur off one of my socket outlets and run up...
