Discuss Step Drill Bits in the Electrical Tools and Products area at ElectriciansForums.net
V
Vitesse
I have a metal clad CU that I am currently installing, it's the MK Sentry one and I want to use the Wago Sprint glands on it. They make a Sprint gland that is 25mm and will accept 2 x 2.5mm T&E for a ring final. The problem is all the knockouts on the box are either 20mm or 32mm.
If I bought a step drill bit that will enlarge one of the 20mm holes to 25mm, will it do it cleanly and give me a nice clean cut enlarged hole? I have not used one before and I don't want to fork out nearly £40 if it just makes a mess of the CU casing. Also if it does what I want it to do, I guess it would be a good investment to add to the tool bag with Amd 3 CU's now required.
i have a cheapo set, 20 quid or something for a set of 3.
and they work very well. make sure you hold the box properly, dont go too fast and use plenty of drilling fluid.
Thanks for that. It looks like Toolstation do one for £20 odd so a lot cheaper than the Screwfix one I was looking at.
The wiska emt glands are spot on for bringing t&es thru a 20mm knockout. However if you want to make the knockout bigger the CK hole enlarging adapters are really good and only about £6
Thanks Sam. Those Wiska EMT glands, I assume that the centre of them is a flexible membrane like the Wiska boxes, and you just punch a hole through them with the cable. Would you get 2 x 2.5mm T&E through a 20mm one for a ring final?
Nope, they're a stuffing gland with one or two oval holes instead of a round one.
Personally I don't see what the fuss is all about, a grommet or bush will do the job just as well.
yes exactly that, 2x 2.5s will fit fine. There fire retardant so in the spirit of 421.1.201!
cheapest I have found them is TLC at £3.60 for the assorted pack
Fire retardant is not in the spirit of the reg, non combustible is, there terms are quite different.
The 960 deg flame retardant grommets that I suggested are more in the spirit of the reg than the standard grommets and bushes that you have just suggested. wouldnt you say?
it doesnt need to be flame retardent the reg is about the enclosure.
i think a brass bush and lockring is better than a plastic stuffing gland.
No it doesn't need to be flame retardant but it's not always about doing the bare minimum,
What IP rating is a 20mm bush with twin and earth going thru it?
Reply to Step Drill Bits in the Electrical Tools and Products area at ElectriciansForums.net
I’ve always been alright with the knockouts provided for Fusebox consumer units but I’ve got a job coming up where I don’t want to use the large...
Hi all, our summer house had a FuseBox consumer unit fitted last year and the guy who did the work has retired. nothing wrong with the install...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
I will start my own workshop and therefore trying to know about all the tools i need for an ideal working environment. In my little journey this...
I need to drill holes in the tile wall for some household tasks. Therefore, I want to know exactly what type of drill bit will suit best our...
4K
