Discuss Strange Earth Leakage Trips in the UK Electrical Forum area at ElectriciansForums.net
I have an odd situation in that I get random earth leakage trips which happen occasionally when I turn off an outside light. I have a standard split board, half earth leakage protected, half not. Trips happen maybe once every 50 times that outside light is switched off, never when it is switched on and never when anything else is turned on or off.
I really don't understand how tuurning something off can cause a trip, can anyone explain how this can happen and what I can do to fix it.
Mick
QUOTE - [ I really don't understand how tuurning something off can cause a trip, can anyone explain how this can happen and what I can do to fix it. ]
Technical term for it is "back EMF".
When ever you turn off a reactive load
then a voltage spike is generated by collapsing magnetic field in the smps ( in this case ) which can cause problems.
Some form of filter will usually fix it,
Try some clip on ferrite cores.
What sort of light is it;
LED?
Halogen, open or glass covered?
Tungston lamp?
How old is it?
Depeneding on what type it is , have you looked inside the light is there any condensation?
Thanks for the replies.
It is a standard single pole light switch, SWA cable to 3 light fittings each with a 21 watt 2D folded florescent lamp.
Ferrite cores
- Where should I fit them, at the switch or at each light, does it matter?
- Does it matter what size?
- On live, neutral or both?
Try changing the switch first for a new one with a quick click on or off action.
Some pictures of behind the switch and of how the SWA is terminated at its beginning, the 3 outside lights and end would be useful.
Are the fittings of the correct IP and do they require and earth or not?
Do the fittings have wirewound (magnetic) ballasts or electronic? If wirewound, what I suspect is happening is that the insulation is low somewhere, and the back-EMF mentioned above is causing it to break down to earth when current flowing through the inductance of the ballast is interrupted. The voltage rises almost instantaneously until an arc occurs at the switch, but if the insulation is low due to moisture, it might result in a brief spike of leakage.
If the insulation is good and the fittings sound, try fitting a snubber network (capacitor and resistor in series) across the fitting nearest the supply end of the cable
Reply to Strange Earth Leakage Trips in the UK Electrical Forum area at ElectriciansForums.net
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Sorry no photos, but I’ll explain best I can. Turn on the switch, I’m not getting any light. Apparently a new fitting. Description…. A white...
Cant get my head round this :( I understand N-E faults cause RCD's to trip, but I cant understand why on these 2 occasions, googled allover but...
