uksparks
- Reaction score
- 1,228
Hi,
Following my threads about using structural steel for the earth...
Well, today was in the area and stopped by the office where the EV charger is going and they are building this building right next door to it, its exactly the same, I stopped and as it happens I managed to speak with the bloke who actually with his very own hands built the office the unit I will be working on.
Anyway, I thought you would like to see some photos of the construction of it so you can see how well its fixed to the ground.
He said there are well over 100 Bolts which are are massive bolts, not little things, they are connected to the ground with 400mm bolts into the concrete which each concrete chunk is 1000mm into the ground.
The Ra should be very good I would imagine. Ill be able to tell you on Saturday when I do the job.
