Discuss Suggestions please ................ in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Ok, got 2 clients asking for similar products ...
Outside "porch" ceiling light with integrated PIR or microwave sensor
Max diameter about 150mm
Anyone suggest anything
So you are looking for a downlight with integral detector ? I know that you can get LED/2D surface take it that would be no good.
Bracken Heath ispot in 20w or 10w has intelligent sensor 4 mins on and sets itself - they are nice. Model 19028W
Driverless bulkhead 1200LM Ra >80
PIR detection distance 4meters
Daylight 5700k
I've fitted a few IP54 ideal for porch
£50 ish 220 x 130 rectangular
re above
The existing light is a downlight - but a replacement doesn't have to be. I suggested the Polo LED but its "too big"
the Brackenheath i9028 is along the right lines
Brackenheath, that's a name I've not heard in a while, we still have some of their R63 40W IP rated downlights in the stores. Not much use now!
Reply to Suggestions please ................ in the UK Electrical Forum area at ElectriciansForums.net
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
Evening all, Currently 1st fixing new extension however the existing cooker hood duct which was on outside wall will now be part of new utility...
Hi, A lot about this fault confused me to be honest. So customer complained the doorbell was not working as intended. By that I mean the chime...
