Discuss Supply type in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
G
graham123
Anybody know what this supply would be? I'm presuming that the black incoming cable is a 2 core as the neutral is from that block and the other 2 phases have been added. That black just looks too small to have 2 cores in it
Don't think it belongs to the DNO. Is there a meter there out of pic? Possibly a sub -main. But as you say bit small for 3 Phase. If sub-main, see where fed from, might even be labeled.
PS; possibly that cable on BLUE Phase, just saw tape on incomer.
could the blue phase incomer be concentric cable, incorporating the neutral?
That's what I think it must be. Looks like a 25mm size. Without takin apart the cutout I Couldent say. I think it must be as th E other 2 red and yellow carriers have been added to make tp
Strange set up but yes blue phase must be concentric here and other tails are separate ... any pics outside ..where are the other tails incoming terminated from?
Reply to Supply type in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
A friend of mine got a 2nd hand coffee machine (OK, probably 3rd or 4th...) for use in a charity cafe and it has problems. First problem is no...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
