Discuss SWA instead of meter tails in the UK Electrical Forum area at ElectriciansForums.net
Hi Gents,
Hope everyone doing good at this hard time,i need your opinion guys
I am installing new CU and Client ask me to install it somewhere roughly 6 meters away from meter box.
i have decided run SWA as i can not use 3m meter tails in this case but my questions are;
1.Can i run SWA through cavity ?
2.What size SWA can i use 16mm or 25mm?
any suggestion what brand and size isolator switch i can use(please send me link)
thank you guys in advance.
Saj
Reply to SWA instead of meter tails in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
I am planning to go semi off grid with a victron and battery system. The system will be installed in an out building about 20 meters away from...
On a new build site how/ why are people getting away with installing meter tails over 3metres in length and behind dot and dabbed walls with no...
Hello again, Was looking at installing yet another dedicated consumer box for my EV charger off the henley blocks and i noticed that a meter...
Just wanted to know which people use. My case. Client converting attached garage into new rooms. Consumer Unit has to move to accomodate this...
