- Reaction score
- 7
Guys, here's the situation; a big house with an 80 metre (or so) garden which has a swimming pool towards the end of it. A few metres further on from the pool is a purpose built pool house (I.e. posh outbuilding), and behind that is the pump/filtration shed. Now, the cable that supplies the pump shed from the house needs replacing, which is simple enough to sort regarding current demand and volt drop etc. However, the guy that owns the place is insisting that because there is a swimming pool involved, then the (necessarily armoured) cable MUST be buried, at least along its' run past the pool. Now surely this isn't the case, as for a start the cable wouldn't be feeding anything or terminated at the pool itself, and it runs metres past it to a purpose built pump room, and is roughly 2.5M to 3M to the side of the pool. In addition, checking the regs doesn't throw anything up about this situation, as far as I can tell they only apply to actual equipment (lights, pumps etc.) that might be used at pool-side. I must admit, the main reason I'm querying this is because I personally haven't been involved in this type of installation before, and the owner of the property is a marine engineer, so I guess I feel a bit intimidated by his possible experience :stooge_curly:! At the end of the day, if it's got to be buried, then so be it, but it would be a hell of a lot easier if it didn't have to be; however I will obviously defer to the wisdom of the guys on the forum, and thanks in advance for any advice people!
