Discuss Switch Outlet Install Help in the UK Electrical Forum area at ElectriciansForums.net
aaranda1
I’m changing a switch for a switch & outlet combo. Where am I supposed to connect these wires? I want the switch to control the light and the outlet to always have power. I’m new and inexperienced. Thank you.
If that is a two-way switch as it appears to be, there is no neutral at all so no power outlet is possible.
If the cables are run through simple and well laid out conduit then you might be able to use an existing cable to pull through its own replacement and a new neutral at the same time. Or you might be able to use a "fish tape" to navigate the route and pull just the neutral through. Neither is going to be easy and it might be the building and cable layout is simply too convoluted to allow it to be done without accessing intermediate points to do it in several steps.
Realistically I would either give up on the dual switch/outlet idea, or get a professional in to do it.
It’s close to the breaker box and they do run through a conduit, I’ll damn an electrician. Thanks for the help.
Reply to Switch Outlet Install Help in the UK Electrical Forum area at ElectriciansForums.net
Hey all - I’m trying to change out a switch only with a combo switch/outlet. After doing the wiring everything seemed to be working but I then...
DYI guy here with some basic knowledge of electrical craft. I am helping a buddy in his remodeled bathroom. His GFCI outlet was powered off vanity...
I am trying to understand how a relay system works and have designed a circuit and a ladder diagram all as attached for an 8 PIN relay, a current...
