- May 13, 2019
- 6,310
- 1
- 10,286
- 13,648,391
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Heavily Qualified Electrician / Teacher / Tutor - etc
I have a customer, a butchers who have a hot water tank to run taps for washing hands and equipment etc.
normal domestic cylinder with an immersion heater.
stat keeps tripping on over temp and needs to be manually reset.
they are using lots of hot water all through the working day.
www.screwfix.com
I have replaced the stat before but it only seems to fix the problem for a short while, stat has not welded closed.
I seem to recall that you can get a red topped version that has its safety function set at 95 degrees instead of the normal 90 degrees.
Am I imagining this or can I get one?
If so please post a link to somewhere I can get one.
many thanks.
Tesla Dual Safety Thermostat 11" - Screwfix
Order online at Screwfix.com. Dual safety system prevents overheating. Not for use with Ariston immersion heaters. FREE next day delivery available, free collection in 1 minute.
many thanks.
