Discuss Thick Architect needs Help!!! in the The Welcome Forum area at ElectriciansForums.net
All the RCBO information I see online only show the outgoing cable and the built in N (in) going to the N terminal connectors and FE wires . None show the return wires as in a ring circuit. The L and E wires are obvious but where does the return N connect to. The N terminal bar or to the out going terminal on the RCOB?
Thanks Andy. That's what I thought and just wanted confirmation. My client wants me to specify all the circuits to be from RCOB's. so I just wanted confirmation before drawing up the spec to go out to various sparks for quotations.
^^ you lost me................ ANY spark knows the answer and won't need to ask.
He’s a different breed - the title gives the answer. We are to doff our caps and not look him in the eye.
He asked question and got answer - everyone’s a winner!
What sort of spec is he producing, if he needs to know where the neutrals on a ring main connect to? I have had some major wirin specs, but none that have actually told us where to connect each wire!
would hate to see the full spec.
Perhaps multi skilled and it’s a ruse for doing the work himself - wouldn’t be the first time ‘one’ has slipped through the net!
met a few architects in my time. most have been skinny bods. still thick though.
We can say what we want - he ain’t coming back! He got what he wanted - typical man!
Reply to Thick Architect needs Help!!! in the The Welcome Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hi Can anyone clear up or explain in a bit more detail what could potentially be causing the results I have. I have just tested a 32a ring main...
Recently changed a CU for a friend and today when visiting one of the RFC's RCBOs tripped. It was due attention anyway as open ring and no time to...
Hi, I would love some help understanding an issue I’m having on a 16mm SWA cable running from the CU in my house to the CU in the shed. I believe...
Hello, I’m need some advice on how a contactor is wired please and where the neutral go. I’m told it is connected to eco 7 and controls 3 heaters...
