A
adam.h
These things are not designed to take swa. Yet when you have a few to do and the wall is a retaining wall you can't put a JB on the back for a flex.
Then it gets more of a pain when you have more then one. So what is the best way to do these things (except to not do them )?
Thought about using a molded box to run a separate swa to each, only you can't gland it properly at the fitting
