Discuss Three Phase Neutral and Earth in the UK Electrical Forum area at ElectriciansForums.net
This is a table giving you an accurate means of identifying when the armouring of SWA cables will and will not comply with BS7671 requirements. As you can see, the required CSA of SWA cables only becomes suspect at cable sizes over 95mm/2core.....
These day's most SWA cables comes with thermosetting insulation (XLPE) as standard. The thermal plastic table, is still handy when assessing or dealing with older cable installations....
Make a copy of this table and you'll never have to ask again, ....If you can use the Steel Wire Armouring as your CPC!! lol!!
PLEASE NOTE.... this table does ''NOT'' relate to equivalent BONDING CSA compliance!!!
Here is an updated table that i have been using for several years now on SWA compliance, for using the armour as your CPC
Figures in brackets, ... DO NOT COMPLY.
Table for 70[SUP]0[/SUP]C Thermoplastic PVC SWA cables.
Conductor CSA
Minimum CSA of SWA to meet 54G
CSA of armour 2 core
CSA of armour 3 core
CSA of armour 4 core
1.5
3.4
15
16
17
2.5
5.7
17
19
20
21
23
35
24
36
40
41
44
49
16
36.1
46
50
72
25
36.1
60
66
76
35
36.1
66
74
84
50
56.4
74
84
122
70
79.0
84
119
138
95
107.2
122
138
160
120
135.3
(131)
150
220
150
169.2
(144)
211
240
185
208.6
(201)
230
265
240
270.6
(225)
(260)
299
300
338.3
(250)
(289)
(333)
400
403.9
(279)
(319)
467
Table for 90[SUP]0[/SUP]C Thermosetting SWA cables operating at 70[SUP]0[/SUP]C.
Conductor CSA
1.5
3.4
16
17
18
2.5
5.7
17
19
20
19
21
23
22
23
36
26
39
43
16
36.1
41
44
49
25
36.1
42
62
70
35
36.1
62
70
80
50
56.4
68
78
90
70
79.0
80
90
131
95
107.2
113
128
147
120
135.3
(125)
141
206
150
169.2
(138)
201
230
185
208.6
(191)
220
255
240
270.6
(215)
(250)
289
300
338.3
(235)
(269)
(319)
400
451.0
(265)
(304)
452
Read more: http://www.electriciansforums.net/e...n-we-use-armour-swa-cpc-11.html#ixzz2BdTJA1PD COPIED from post #155 of this thread
Reply to Three Phase Neutral and Earth in the UK Electrical Forum area at ElectriciansForums.net
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
If cpc core is present i.e. it's either 5 core three phase or 3 core single phase — is a banjo connected with a brass screw into steel trunking...
I have a scenario where there is a three phase DB in a commercial property where there are mixture of three phase and single phase washing...
I have been asked to provide a quote for a supply to an toilet block on a campsite. The three phase supply to the campsite is approx. 150m from...
Hi all Suggestions please. I’m working on a 3 phase shop install with a bunch of typical circuits. As each cct is energised the earth leakage...
