Hello, I have a 12VDC battery bus where I charge with solar PV and a wind turbine. The system is controlled using a Siemens PLC. When there is a system fault, the PLC will open all relays, but this included relays that power the PLC itself (example an emergency pushbutton). When restarting the system (Black start), I need a way to temporarily connect the batter bus to the Inverter that powers the PLC. the current upon start up I believe will be as high as 30A, so I am looking for a solution that will allow about 50A to pass for about 5mons, and then automatically switch it self off. I am currently achieving this using a manual breaker, but the risk is someone forgets to switch off the breaker. Can anyone recommend a time delay switch that can work here (max 150VDC, 50Amps)? I am trying google but not really getting anywhere. I suspect there are existing electrical systems that have a similar black start requiement.
