Discuss To bring lighting circuit up to regs... in the Australia area at ElectriciansForums.net
SSE
Adding downlights onto a circuit for someone and it is an old fuseboard with re-wireable fuses. Am I correct in thinking that all I need to do is upgrade the circuit I am workin' on or does the whole fuseboard have to be brought up to 17th edition? All I was planning doing was adding an rcd unit with an mcb onto the side of the fuse board for it...
Is the change of lights in a "special location"? If so you will need a RCD if not you don't.
It makes no difference if it's in a special location or not, if your installing new cable within the Walls and above ceilings then the cable will need RCD protection, MWC issued and notification to LABC if required.
Notification to LABC???????
if it's a mod. to an existing circuit, then as long as it's not a special location, only need RCD if cables buried in walls <50mm blah, blah, and non notifiable. a MWC will cover the work.
If it's not a special location then as tel says, no notification needed, just issue a MWC to customer and your done
Reply to To bring lighting circuit up to regs... in the Australia area at ElectriciansForums.net
As I've mainly done site work and moved into domestic recently, I'm a bit rusty on stuff like this, but if I'm adding a loft PIV unit to an...
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
Hi all, I have two questions regarding wiring and containment on commercial property stairwells in Ireland. We are currently wiring a 3 story...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
