Discuss Transformer help needed in the UK Electrical Forum area at ElectriciansForums.net
jaydub
Hi, I've come across this 40 year old transformer.
It's 400VA with 240V AC input, 13/16V AC output.
Its for swimming pool lights.
Could anyone shed any light (excuse the pun) on the definition of 'CTE' and if there is a modern equivalent exactly the same as this?
I can find very similar transformers but with a 12V output, would this matter? I'm not sure...
Any help appreciated, thanks
CTE means centre tapped earth. This is on the secondary side of the transformer. It basically means that the centre of the secondary is connected to earth meaning the maximum voltage to earth in your case would be 6 volts.
110v Portable tool transformers are usually connected this way meaning max voltage to earth is 55 volts.
This will sound daft but there is nothing wrong with it but the client just wants it replaced with a modern, new one as he has had the pool system updated.
That's the exact idea that I was just contemplating, seems a bit naughty but it would solve my problem and I could just sell it to him as 're-conditioned' :D Thanks guys
If there is nothing wrong with the existing TX, why change it? how much will a new one cost him?
Think you will find that is fraudulent and I hope you are not being serious.
Just to clear up any misconceptions here, I will and always do explain to my customers in full detail what it is that I am carrying out for them. A successful business is built on trust between a spark and his clients, you will not get far ripping people off! I hoped that the green face was enough to clarify my sarcasm in my previous post.
Thanks for everyone’s helpful input and I hope that has cleared things up.
you said not us!
You can find new equivalent replacements but I wouldn't see a replacement as being an improvement unless there's a corrosion issue. The old one is probably better made and will probably outlast than a new one TBH. Just replace the enclosure if you're worried about the aesthetics
Reply to Transformer help needed in the UK Electrical Forum area at ElectriciansForums.net
Hi folks I've just identified as cause of lighting circuit tripping in consumer unit a low volts ceiling light with laride transformer taking in...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi, DIY’er here. I need a replacement transformer but can’t find the exact model required anywhere. It is Golden Power GP-SW120DC0700(UK)...
Hi all, No electronic knowledge here. The plug/transformer of a led lightstring is fried. Now I am trying to find a replacement on Aliexpress...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
