Discuss tripping induction hob in the Electricians' Talk area at ElectriciansForums.net
Hi guys
Interested in your thoughts here. I recently installed a new circuit to supply an induction hob and oven. The circuit is supplied via a 40 amp rcbo. The rcbo however is intermittently tripping, sometimes when it's not even in use and stone cold I.e no fan etc running. I know the loading is correct and this is not an overload fault.
I'm thinking it's a faulty oven unit/hob unit - it's brand new and straight out the box.
Or do induction hobs require a type c breaker to cope with the inductive load - if that's how they work? Iv fitted induction hobs before in type b breakers and never had a problem.
Any thoughts?
Thanks.
Dan
It is quite common for elements to absorb moisture and trip RCD's. This is why it will do it when not in use.
Is the double pole switch off when it is tripping?
It may well be a mineral element then. Sometimes drying them out solves the problem, but there is no guarantee that it will not do it again. RCD's are not ideal for cookers unfortunately. (you will have to be ingenious to dry it out lol :wink5::wink5:)
Try the suggestions for IR first though.
The very first induction hob I did many moons ago had the same problem, after speaking to the manufacture I was advised to run feed in swa and omit rcd protection as induction hobs had a tendency to trip rcd.
Complete bo***cks I thought but as the cu was literally in the next cupboard and house was still being refurbished this is what I did.
I've never had issues with induction hobs and rcd's since that one but it could be same make? Cant remember make of that one but probably called something like Bonko bought for peanuts off ebay.
Reply to tripping induction hob in the Electricians' Talk area at ElectriciansForums.net
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
We have an install where the client has supplied an induction/gas hob combination unit. We have a 6mm cable supplying the hob, the induction part...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
Hi all, I've just tried wiring an indesit IB65B60 induction hob. I read the instruction manual and it said for 240v connections to put the...
4K
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
