Discuss Under cabinet lighting in the UK Electrical Forum area at ElectriciansForums.net
Hi, am installing under cabinet lights as part of new kitchen installation. Would prefer to use 230V light fittings, but one,s I,ve purchased only allow one cable into them, so will need junction boxes. The junction boxes will be on top of the cabinets and lights on the bottom of the cabinets. Also the light fittings only allow cable access to them through a hole drilled into the bottom of the cabinet. So was a bit concerned that 230V cables (four of them) will be going through four different cupboards. Is this pretty standard practice or could I do better. Thanks
drill up at an angle to come out behind the cupboard/s in the space behind the back panel.
most do, but you'll need to drill the top board against the wall. see if the backboard (usually thin hardboard) flexes. generally 8 -10mm void behind it. sometimes it's easier to take the cupboard/s down to get cables in, then refit.
Reply to Under cabinet lighting in the UK Electrical Forum area at ElectriciansForums.net
Ive got an old T5 (or4?) fitting to change to LED, but its built into the kitchen cabinet between two shelves of glass. Is there any like this...
Hi All. I need to extend the cables for a 3 plate ceiling rose/pendant on ground floor ceiling by 450mm. Can I fix the ceiling rose/pendant to...
I live in a warehouse condo, converted about 20 years ago. The building dates to about 1870 but with the conversion, all of the electrical was...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
